turbo motor questions
Im looking into building a turbo L28, how much do JE pistons usually go for, and how strong is a non-turbo L28 block? I know the turbo blocks have siamese bores but is this really needed for a reliable 300-350hp motor? I know where there are plenty of n/a L28s I can get for pretty cheap and I'd like to use one of them if I can.
Their really is not a turbo motor per say. What you need to look for is F54 satmped on the side of the block. this is the same block as the so-called turbo block w/ the simesed cylinders. these blocks can be found on late model N/A 280zx's. good luck w/the project
