Guest Anonymous Posted January 27, 2002 Share Posted January 27, 2002 I believe HKS has made an exhaust manifold for the vg 30 engine to accomodate a t-4 turbo. Can anyone get me up to speed on the availability, effectiveness and cost of this manifold. Quote Link to comment Share on other sites More sharing options...
threeZguy Posted January 28, 2002 Share Posted January 28, 2002 According to info I've seen on some other boards,HKS doesn't make the manifold anymore. It has now become the "Holy Grail" for those of us with z31's. But with all the combo's available for a T3/T4 setup, it seems the time and money spent trying to find one could be used for other gofast goodies. There are people pushing up to 500 hp and over on a VG30 with T3/T4, aftermarket EMS, and nitrous. This is the route I am going. Just my 2 cents. Chris Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 28, 2002 Share Posted January 28, 2002 to late, I already have a t-4. On paper it looks to be a good fit. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 31, 2002 Share Posted January 31, 2002 Although I am running an L28 engine, I ran into a similar situation. I am using an HKS-T04E, with the L28ET mainfold ported. I picked up a T04 flange and had it welded on after much searching. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 1, 2002 Share Posted February 1, 2002 Where did you put the wastegate. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 1, 2002 Share Posted February 1, 2002 I put the wastegate at the bottom of the manifold, between cylinders 1 and 2. I used a dremel tool to cut the manifold, then welded the wastegate flange. The wastegate is a Turbosmart 45mm Progate , with V-band inlet/outlet. I just sent the manifold to AZ to be coated (in/out) by Jethot Coatings. I'll snap some pics when it returns. [bLOW, BLOWN, BLOWN UP] Quote Link to comment Share on other sites More sharing options...
