Guest Anonymous Posted January 31, 2002 Share Posted January 31, 2002 I just picked up an intercooler from a MKIV Supra for $70. Thing is a LOT bigger than I thought. Any ideas how to fit this thing? Steve Quote Link to comment Share on other sites More sharing options...
spork Posted February 7, 2002 Share Posted February 7, 2002 sorry, I can't help you on fitting that intercooler in place, but I don't suppose you could tell me the deminsions of it with the inlet and outlet sizes, could ya? I've been in search of a good intercooler for sometime now, but haven't been able to come up with deminsions of the one you have. thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 7, 2002 Share Posted February 7, 2002 Give or take its core is 10 X 11 X 6 (w x h x d). Has 2.5" in/out. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted February 7, 2002 Share Posted February 7, 2002 I would turn it 90* clockwise to begin with, then put an immediate 90* bend on the top pipe. Open up the OEM hole on the drivers side of the radiator as big as you can get it, then run the top pipe to the TB and the bottom pipe to the turbo. Unfortunately that leaves the air filter in the engine compartment. Another option is positioning it so that the straight outlet faces down and the bent outlet faces the hole by the radiator and route the bottom pipe under the radiator support. Unless you are going for MEGA-HP, that pipe does not need to be bigger than 2.25". You can then route the TB pipe and a pipe for the filter through the radiator opening. Quote Link to comment Share on other sites More sharing options...
