blow off valve
If you have a BOV, do you have to have the emergency relief valve? I want to run the non egr 75-76 intake and they don't have a place for the emergency relief valve.
It's good that there's no place for the Emergency Relief Valve, also known as the "source of confusion valve", you don't need it if you've got a functional wastegate. Besides, as another member pointed out, if you incorporate an Eclipse Compressor Bypass Valve in your system it can function as an inadvertant ERV (pop-off valve) anyway.
DAW
