Guest zthang43 Posted March 23, 2002 Share Posted March 23, 2002 Anyone have a turbo they want to get rid of from a 87 or 86 Toyota 22R Turbo? I just pulled out the one in my truck, and it is in pretty bad shape. About this much -> <- play in the shaft on either end; the impeller on the exhaust side has some holes burned in it, and the casting is cracked. Also, the casting around the wastegate valve seems like it's melted; the wastegate doesn't seat very well. Is that how the wastegate is supposed to be, or is that part messed up too. There is a gap big enough for your finger between the exhaust impeller and the wastegate valve seating area, so exhaust gas can always get past the impeller even if the wastegate is closed. Is that how it was made, or is a huge chunk of casting missing??? Quote Link to comment Share on other sites More sharing options...
Guest zthang43 Posted March 23, 2002 Share Posted March 23, 2002 Sorry this isn't Z related, but I figured you guys might be able to help. I pulled the turbo completely apart today, and it is one messed up piece. On the exhaust side, the housing is cracked, and the part of the casting between the wastegate and turbine wheel is completely burned away. The wastegate seat is also eroded a bit. My question is this: does anyone know about welding on cast iron to fix something like this? I can't afford to spend $800 for another used turbo, so I was thinking about filling the crack and the burned out section with a mig welder. I'm a fairly decent welder, but I have heard somewhere that cast iron will crack if it is welded. I had to cut and weld the exhaust manifold for the 4.3 in my Z to make it fit, and it seems to be fine, but it doesn't get as hot as a turbo, of course. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 25, 2002 Share Posted March 25, 2002 I just was going to suggest TEC that had a kit for these trucks solving all of the oiling issues (oil line is too close to exhaust pipe and get coked up bad), but I just read your second post saying you can't afford too much for a fix. have you tried talking to Majestic Turbochargers for a rebuilt one? Otherwise, it's junkyard search time Wish I could help you more... Davy Quote Link to comment Share on other sites More sharing options...
Guest zthang43 Posted March 27, 2002 Share Posted March 27, 2002 Well I welded it up today so we'll see what happens. Quote Link to comment Share on other sites More sharing options...
