79 ZX conversion
Hi,
In the course of my research, I am becoming more confused. What other alternatives to John's cars and the MSA kits are there? I see that there are number of members of this forum that have done this swap. How is the handling of the converted ZXs in spite of the firewall/hood clearance issue? Can these issues be resolved by front-end weight reduction alone. (aluminum heads/waterpump/battery relocation, etc.) The car I am thinking about converting is a 79 5 speed with no power options and analog gauges. I want to use a 92 Z28 drive train with an automatic transmission. Is it possible to run the FI without using an aftermarket engine controller like an Electromotive tec2? How?
Thanks,
Warren
Guest greimann
A very reasonable alternative to purchasing a kit is to do it yourself. If you have a steering box rather than a rack and pinion, then the engine mounts can be just a flat plate to adapt the bolt pattern. This setup puts the distributor about 1" from the firewall and there is enough room under the hood for a 3" high drop base air cleaner. You will have to run down a mid 70's Camaro exhaust manifold for the drivers side to clear the steering box.
Aluminum heads and manifold will help weight distributuion, but when I was running iron heads on my '79 V8 the handling was not noticeably different except for the ample availability of power on oversteer. icon_biggrin.gif
There are a few pix here of my setup:
http://zdriver.com/rides/detailride.php?cat=2&relIdx=2&vehId=571
I don't think one can give a generalization about handling of the V8 converted ZX's. Here's why: they are not on the same chassis as a 280Z, period. They are different, yes, but even when converted, they still handle well. Ross Corrigan is the only guy I know personally on this site who has a very nice converted ZX that he takes to the track on occasion. His car is set up very well and apparently handles very well too icon_smile.gif See pics at http://www.modern-motorsports.com/miscpics/mycar/aug19.htm
HTH,
Davy
