Guest Anonymous Posted January 10, 2002 Share Posted January 10, 2002 I have a small transmission fluid leak coming out on the speedometer cable. It isn't much with a few drops when I stop . It is a TH-350. I know there is an o-ring seal around the Speedo housing, but it looks like it is coming out where the cable goes. Thank You, Rick Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted January 10, 2002 Share Posted January 10, 2002 Try packing that area inside the socket and cable with grease. Also, try to find an o-ring that will fit inside the cable coupler nut, so the flared end of the cable that touches the speedo connection on the trans is sealed. Quote Link to comment Share on other sites More sharing options...
