Guest Anonymous Posted February 4, 2003 Share Posted February 4, 2003 I've been searching for about the last hour and I can't find jack on where the oil feed for a stock turbo L28 comes from? In the Haynes manual all I can find is that the oil filter mount is different but from what I can find on here and Zcar.com it sounds like the feed comes from the pressure sender? Seems strange that it comes from the other side of the engine though? I've just bought a turbo off a Skyline and I'm putting on my NA Z but it didn't come with oil lines so i need to get some made up, just need to figure out where the feed should come from. Thanks. Quote Link to comment Share on other sites More sharing options...
z-ya Posted February 4, 2003 Share Posted February 4, 2003 It connects to a Tee where the oil pressure sender is (next to the oil filter). You need to get the NIssan Tee, or re-tap the block for 1/8 NPT and do whatever you want. Just don't get any metal chips in the oil galley (rebuild time). Pete Quote Link to comment Share on other sites More sharing options...
