Guest Anonymous Posted December 27, 2001 Share Posted December 27, 2001 I am about to start hte first phase of my project. The removal of a donor engine and tranny from my old Dodge van. It's a 85 318, 727 torqueflight that will be rebuilt from the bottom up. My question is....... (drum roll please)..... What parts should I pull in addition to the engine/tranny? I am assuming that I keep the driveshaft, radiator... But what else? Alternator, starter, smog stuff (as I hope to keep it CA legal). How about the electronics? Any ideas? I can use all the help I can get. Thanks in advance!! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2001 Share Posted December 27, 2001 Keep everything that is hooked to the engine. From the aircleaner to the oil pan. I don't know about the radiator it depends on the dimentions. The radiator I will be using for my z is 19x24. I don't know about the radiators for vans. hopefully your radiator will fit cause it will save money. You'll need the started unless you buy a new one which would help with clearence issues but I don't think it's absoulutly necessary. keep the driveshaft cause youll have to use one end of it anyway. As for the alternator I will just use a one wire seems alot easier than the chrysler one. Of course I will need to make brakets. I don't know much about your smog issues 'cause we don't have them here (I know I'm lucky). What year is your Z? from what I heard 73 and older don't need smog in Cali. best of luck and keep us posted on the auto tranny Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2001 Share Posted December 27, 2001 Thanks Landis, The Z is a 79 zx coupe. The current l-28 will be moved into a 79 zx 2+2, whose motor needs a rebuild. Once the van is gone and the 2+2 is running, then the rebuild of the 318 will begin. Then I plan to build the backup L-28 from the 2+2 (factory original) and replace the 2+2 back to factory condition. Then I will complete the v-8 transplant to the coupe. Sounds complicated doesn't it. I will be a regular on the board as I progress. Quote Link to comment Share on other sites More sharing options...
