Guest ScaryFast Posted August 10, 2002 Share Posted August 10, 2002 I just picked up a 400bb to put in my '66 Satellite and I am in the process of tearing it down. I need to know the order in which to remove the head bolts so I dont screw anything up. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 11, 2002 Share Posted August 11, 2002 Is there a sequence for REMOVING head bolts? I know theres a sequence for torquing them down, but removing? The sequence for torquing you'll have to look up but generally its starting in the middle bolts and working circularly to each bolt farther out as you continue. I've never used a sequence for removing them though. Anyone else heard of this? Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 11, 2002 Share Posted August 11, 2002 Yes there is usually a sequence in unbolting head bolts, it seems like Lone says, start in the middle and work your way out or just do it in reverse of what the order is in torqueing or tightening them. Quote Link to comment Share on other sites More sharing options...
