Guest blown408 Posted December 14, 2002 Share Posted December 14, 2002 Hey guys. I'm currently working on a blown 408/nitroused Dakota R/T project. The cool thing is, that i'll have a 360 out of the r/t just "lying" around Is there any problem using the 1982 non-turbo 5 speed for a 300hp project? I don't want to make is so radical that it's a complete re-engineer, i.e. tranny, rear end, etc... Also, is there anbody that makes adapters for the mopar swap? I think that chevy swaps do, right? Transdapt? I think that's enough for now, eh? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 14, 2002 Share Posted December 14, 2002 Somewhere, somehow in some way you may find an adapter to fornicate a foreign six cylinder transmission to a domestic V8. They say the Borg Warner T 5 was a weak sister bumping and grinding behind the Turbo L 6. Your hair will be retained and stay the same color longer if you go MOPAR or use some adapter to mate MOPAR with a tranny of known and proven pedigree. And $$$$ ahead in the long run Quote Link to comment Share on other sites More sharing options...
Guest blown408 Posted December 14, 2002 Share Posted December 14, 2002 Maybe i'll just see about a T56. It's still a ways off, but i like to gather parts ahead of time. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 30, 2002 Share Posted December 30, 2002 What about a Toyota R-154 5-speed from an '87-'93 Turbo Supra? They are essentially the same transmission as the AX15 that Dodge uses in their trucks with different internal ratios. I think they even have the same bolt pattern at the bellhousing. Quote Link to comment Share on other sites More sharing options...
