New Manifold?
Guest KraZ4spd
Guest KraZ4spd
I know we had talked about a type of manifold that would connect the opposing cylinders for a very unique sound. I know that there was a gentleman trying to figure out how to make this work. What if we had a manifold that was four in & two out on both sides? You could then run 4 small exhaust tubes down the length of the tranny and connect them in the order. Still making it easy to access the tranny and not have to cut up the firewall. Behind the tranny you could then go into a dual exhaust setup. What do you think that would sound like?
weird.gif:confused::cool:
Dr gas says that a good x-pipe also sounds like 180 degree headers. I think you would lose power with set up you suggest. The secound pipes would be to long. I have had conflicting info on the subject. The only real reason i would go the 180 degree header way is if i was sure i would get more power. Grumpy said they will but didnt mention how much or if it were worth it. I do wonder why they are baned in a lot of stock car classes though? Must be something in it.
Cheers
Douglas
