VRJoe Posted January 26, 2002 Share Posted January 26, 2002 OK, OK I've read all the info about using a 94-97 T56, but I've got an unused 98 T56. I really want to use this setup with the hyd. throwout bearing. I'm going to check with a machine shop I work with and see about having a 1/2 inch spacer made and then would be able to make these available to others, but I've also considered simply shortening the input shaft by 1/2 inch. I think this might work with the right flywheel/pressure plate combo. I need to make a few measurements for comparison, so I'll let you'll know how this goes. Any input or thoughts would be welcomed. _ VRJoe I've never questioned my sanity, but others have. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted January 26, 2002 Share Posted January 26, 2002 Sounds like a great plan; I hope it works! Good thing is that if this works out, you'll be able to offer that piece to all other rodders who could do exactly the same thing with their cars too! What this means is: you'll be able to make a buck or two for yourself. Davy Quote Link to comment Share on other sites More sharing options...
