Guest Anonymous Posted October 19, 2002 Share Posted October 19, 2002 I really want to run side pipes on my Z but ground clearance would seem to be an issue. I want 2.25 straight pipes but when it wraps from the engine bay under the body to the rocker panels it seems too tight. Anybody know the going rate on getting flattened oval type pipes installed? Just on that 1 foot or so section under the floor pan. Or alternatives? Quote Link to comment Share on other sites More sharing options...
Guest shortyz Posted October 19, 2002 Share Posted October 19, 2002 clearance is fine. i used mandrel bent 3" and its nice and tight and wont hit. http://www.clanace.com/~shortyz/the240/ look at exhaust pics Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2002 Share Posted November 5, 2002 Great job on the side pipes. I am all over this. Where did you pick up the actual side pipes? How heavy are the pipes? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2002 Share Posted November 5, 2002 I would like to add that the Tomahawk Z kit utilizes the Cobra style side pipes with the exhaust pipe running even along side the rocker panel not beneath the rocker panel by exiting the pipe from a cut out section in the fender. Quote Link to comment Share on other sites More sharing options...
Guest Ziggy Vulcan Posted November 9, 2002 Share Posted November 9, 2002 Where can I get my hands on a coba style sidepipe? Are those the ones that have the ends of the headers showing behind the wheel? I found some sidepipes from jegs but those aren't quite what I'm looking for. I'm definately putting sidepipes on my car. Quote Link to comment Share on other sites More sharing options...
