Jason81NA,82RBtt Posted November 9, 2001 Share Posted November 9, 2001 Can my Crane HI-6S and my SDS EM3D share the same MAP sensor? Or will that cause some kind of conflict? Thanks Jason Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted November 9, 2001 Share Posted November 9, 2001 Jason, I assume you are using the boost retard mode feature. Just curious why you did not just go with SDS "E" or even "F" and let the SDS do the ignition control. Anyway, that is a really tough question to answer since you have to figure out how to combine the 2 wiring harness into a single plug on the MAP sensor. I would call either of the vendors and ask because there is a possibility the warranties could be voided, especially if you have to return the faulty item and they see the wiring harness mod. Quote Link to comment Share on other sites More sharing options...
