Holley Projection 4
Guest jwelch
Guest jwelch
Greetings,
I'm having problems with the return line on my 77 280Z. This car originally had FI so I assumed that one of the lines on the sending unit was a return. My fuel pump will not work when I hook up the fuel lines. When I unhook the lines the pump works fine. Does anyone know which on of the lines on the sending unit is a return line or if the return line can be used in the gas filler tube? Any help is greatly appreciated.
Thanks
John
77 280V8Z
