Holley Stealth Ram
hi all-
i have searched through the past posts on this topic and i think i have decided to go with it... i'm currently (slowly) doing a 350 swap into an 87 ZX and want sooo badly to run a TPI system. I have looked what seems like everywhere and thought i would ask the guru's here - where is the best place to find it?!
i am looking for the entire unit, ECU, harness etc.. (i don't really want to mess with hooking it up to another ecu). Also, i want to be able to program it rockon.gif !
any suggestions?
thanks, Nick
To find a stock TPI, Stealth Ram or what? And where have you looked? Try Ebay, Stock TPI's complete can be had there usually reasonable, but make sure everything is there. The stealth ram is rather new and not sure you'll find one on Ebay yet, but who knows maybe. If your looking for a new stealth ram then Summit or Jegs should be able to help you out. The stock TPI as you might know if you know about the stealth ram will run out of steam by 5k usually, siamesed ports and all that help a bit, but the plain truth is the runners are very long and tuned for torque not max HP. Good luck with it.
Regards,
Lone
