Measuring for push rod length
Ok, I need some help. I’m in the process of installing the heads on my engine (TFS 23deg) and was wondering how you go about measuring for the push rods. I’ve got a push rod length checker. My questions are:
1. What is ZERO lash?
2. When checking length what position should the rocker arm be in TDC, Intake stroke, compression or power stroke? (I’m guessing TDC)
3. Where should the rocker arm be positioned on the stud? Screwed all the way down (bottomed out?)Or backed off 1 or 2+ turns?
4. Should I be taking the measurements with a feeler gauge in place (at the valve tip) for clearance? (I’m guessing yes here)
Thanks in advance for you help, thoughts and advice.
David
My set up
350 ci .030 over
Speed Pro hyper coated pistons
Eagle rods
TFS 23 deg heads
Comp cams mech roller, CAT roller lifters
Scorpion roller rockers 1.5
ARP bolts
