Guest jt240z Posted October 26, 2002 Share Posted October 26, 2002 I just aquired a free AEM (unused) universal fuel pressure regulator (P/N 25-302R) and I though it would make a good match for my custom fuel rail. I have some questions before I begin my installation: 1: Just to make sure that my understanding of operation is correct, here is the way I understand the interconnection of parts to be, using this regulator: Fuel Tank Outlet-> Fuel Pump-> Fuel Filter-> Fuel Rail-> To either side inlet of FPR(25-302) out the bottom port of FPR to Fuel return line-> Fuel Tank Inlet. Please let me know if my understanding is wrong. 2: What are the fittings used to connect the inlets and outlet ports to -6AN hose? 3: What do you use to block off the unused inlet port? Any help I can get on this would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
SHANE Posted October 29, 2002 Share Posted October 29, 2002 your routing is correct. if your regulator is like the paxton one then you would use o-ring boss fittings. on mine i used -10 o-ring boss plug, -10 o-ring boss to -8AN adapter. Quote Link to comment Share on other sites More sharing options...
