TB's to replace triple Webers?
Guest JAMIE T
Guest JAMIE T
What are differant companies that make Weber replacement TB's? I know of TWM, and I have seen some old HKS versions on Ebay. How much do the TWM units cost? I'm thinking about going this route later.
If you already have webbers, could you not just gut them (leave the throttle valve in though), and weld/epoxy injector bosses to the intake runners? I was always curious if this could be done...
Nigel
'73 240ZT
Guest JAMIE T
I don't have Webers. I just wanted individual TB's for a EFI system. I can build my own manifold, but figured if the TB's are affordable enough, then I would go that route since they look awesome. I found prices for the TWM TB's. They are between $300-350 each. So a minimum of $900 just in TB's. WAY too much for me. I guess I'll just use a single TB set-up like the stock one, just better.
