Guest JAMIE T Posted January 12, 2003 Share Posted January 12, 2003 I have this T-Rex fuel pump(came with my original Vortech kit) left over from when we put the Paxton 1000hp pump and shitz on my old 'Stang. Would this pump alone be enough for a L28ET with higher than stock boost levels? Maybe up to 14psi(or higher if you say so). I think the specs are 50gph/70psi. I think it is a Walbro pump. I say this pump alone becuase the L28ET is going in a 240, that doesn't have a EFI type pump already. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted January 12, 2003 Share Posted January 12, 2003 I used that same pump up to 15 psi with no problems. It would probably work much higher than that too. I swapped it out because it was very loud. I bought it used on Ebay though so it was probably on it's way out. I'd be willing to bet it is made by Walbro too. If you peel the Vortech label off it looks just like the Walbro 255lph HP pump I have. Except the new one is much quieter Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted January 13, 2003 Share Posted January 13, 2003 Its good... Quote Link to comment Share on other sites More sharing options...
