Guest Anonymous Posted February 18, 2002 Share Posted February 18, 2002 how much trans tunnel modification for a 350 turbo in a 77 280z w/jtr setback plates i have a hei dist. but plan to use hood pins in place of the stock latch. thanks rick Quote Link to comment Share on other sites More sharing options...
DavyZ Posted February 18, 2002 Share Posted February 18, 2002 Rick, Don't mean to dump on you, but you should really post this in the chassis forum, not the Chevy engine forum. Anyway, the answer is 'none.' Or, if you need to do any modifications, it will be the transmission tunnel brackets--they MIGHT need to be removed. Hopefully there will be enough room that you don't have to do anything at all. Hope this helps. Davy Quote Link to comment Share on other sites More sharing options...
