jgkurz Posted February 26, 2003 Share Posted February 26, 2003 Hi all, I was offered a potentially sweet deal on new turbo for my Z. I am friends with a local Audi/VW/BMW tuner shop. that does custom turbo kits and EFI's. They have an extra dual ball bearing GT58 turbo that they offered to at cost. All their turbos are done by Innovative so I'm confident it's a quality unit. Below is a list of my engine specs. The turbo I currently run is a Jim Wolf Sport 400 AKA T04E 50Trim Compressor with a 10 blade stage 5 wheel - .63 AR turbine housing. It spools very quick, but doesn't have room for big HP. Is a GT58 too big for my setup? I don't want a car built only for top end power. I'd like full boost in by at least 3K if possible. The car will be used on the weekends for road trips to the beach, autocrossing, drag racing and a track day at PIR occasionally. Someday I'd like to make 500 flywheel HP or more and I know my current turbo is wrong for that goal. Am I asking too much? Do I need to settle for a car that does one thing great, but not both? Thanks 1982 L28ET Block 2999cc 87.5 bore 83mm stroke Crossdrilled and balanced diesel crank 7.6:1 JE Pistons Full floating wrist pins SpeedPro Plasma Moly rings Race prepped late L24 rods ARP Rod & Main bolts ARP Cyl Head studs O ringed block Mildly ported P90 head with backcut valves ISKY 490 turbo camshaft with Crane springs N42 Non EGR Intake with major porting Weber 60mm Tbody Nissan competition oil pump Scottie downpipe with 3 inch mandrel exhaust Maxima hi flow water pump Electromotive Tec3 EFI TurboXS BOV 440cc injectors - Will go bigger when needed NPR IC with 2.5" inlet & 3"outlet - in process Custom fuel rail with adj FPR - in process Walbro 255 lph fuel pump - in process External Tial wastgate - in process Blitz SBC Type R boost controller - in process Quote Link to comment Share on other sites More sharing options...
