Guest shuyun Posted March 3, 2003 Share Posted March 3, 2003 For a Turbo L28et what numbers should I rebuild on and what numbers will be safe to run on ? Thanks? 180,000 miles Quote Link to comment Share on other sites More sharing options...
Guest das280zx Posted March 21, 2003 Share Posted March 21, 2003 I think my haynes manual said the turbo should be around 145, with anything less than 100 psi needing a rebuild. My engine, with 100k+ on the engine had from about 130 to not quite 140 psi. Not too bad, I guess. Also, make sure all cylinders are within about 10% of one another. One really low cylinder means you need a rebuild. Quote Link to comment Share on other sites More sharing options...
