Guest Anonymous Posted March 3, 2003 Share Posted March 3, 2003 i tried running a search but came upon pages and pages of unrelated material.. my passenger side window is stuck and will not roll up. would i need a new regulator? if i wanted to do a power window setup, would it work with that regulator? or should i not even bother buying one if i get the power window kit from autoloc. thanks for the help Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 3, 2003 Share Posted March 3, 2003 I would check your window tracks, where your window glides up and down. These tracks usally have a felt liner to keep things quiet. After 20 - 30 years the felt starts to crumble and may get clogged in the track, so when you raise your window the wheels get stuck. It could also be old hard grease sticking things up. You need to look inside and see why it is getting stuck. The regulator is probably fine. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 3, 2003 Share Posted March 3, 2003 thanks, i'll check that out Quote Link to comment Share on other sites More sharing options...
