Guest Drewz Posted March 6, 2003 Share Posted March 6, 2003 Okay before I tear down my 72 302 I want some poinions first. This is in my truck and it sometimes will puke out antifreeze, or run fine, heat disappears, or I check the rad and it is low but when I start it it is full. There doesn't seem to be oil in the antifreeze I checked it cold and hot. I replaced the thermostat, waterpump was toast and made sure the rad was flowing well. When I burp the air out of the system the heat is great, it runs fine, and there is no smell from the exhaust. I drive it to work and I thought I saw a little smoke (but it is cold out) when I get to work which is 7 kms the rad is full and heat is fine. I let it sit half the day and the rad is low. When I drive home the rad is real low (4 to 6 liters). A couple of the plugs seem fairly white off of the drivers side and the other two are a nice light light brown. There is a little grey foam in the breather filter but not in the valve cover when I look in the oil filler cap side. I was told head gaskets aren't common on 302's but I think the guy I got it from overheated it.Also there was a little foamy oil that came out of the dipstick tube ONCE. The tube and dipstick are clean now so I need to double check my assumption that the head gaskets are toasted. I don't have access to a cooling system pressure tester or I would go that route as well. HELP ME!!!!!!! Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted March 6, 2003 Share Posted March 6, 2003 Blown Head Gskt or Cracked Cyl Head. When the Spark Plugs are spot clean-it means they are being "Steam Cleaned" by the hot coolant as it passes through the combustion chamber. Hope I read your question/post correctly. If you are not leaking coolant, water pump is not leaking, nor your dipstick sludge-brown: and are still loosing coolant-then you have a blown head gasket or cracked cyl.head. How often do you have to add coolant: everyday? Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted March 6, 2003 Share Posted March 6, 2003 every day is right. I am pretty sure the gasket is toast they way it is acting. How likely is it the head is cracked? I thought that was real rare on a V8? Quote Link to comment Share on other sites More sharing options...
