Guest Mr. Big Business Posted March 12, 2003 Share Posted March 12, 2003 To anybody who's using a T56, where did you get your electrical connectors/plugs for the reverse switch and speedo connector? Mine came without any. For those of you using a Tilton MC and/or Wier bellhousing with hyd. throwout bearing, What/where/how did you get your clutch line? My tilton came with a male-male fitting that (I think) is -4 AN, and the weir clutch has what they claim to be a 'standard brake line fitting", which is a male inverted flare fitting. HELP! Should I just make the hose with aeroqip or earls braided hose and those screw-on fittings, or buy one already made? (Why are those stupid fittings so expensive? ) Thanks, Henry Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 12, 2003 Share Posted March 12, 2003 To anybody who's using a T56' date=' where did you get your electrical connectors/plugs for the reverse switch and speedo connector? Mine came without any. For those of you using a Tilton MC and/or Wier bellhousing with hyd. throwout bearing, What/where/how did you get your clutch line? My tilton came with a male-male fitting that (I think) is -4 AN, and the weir clutch has what they claim to be a 'standard brake line fitting", which is a male inverted flare fitting. HELP! Should I just make the hose with aeroqip or earls braided hose and those screw-on fittings, or buy one already made? (Why are those stupid fittings so expensive? ) Thanks, Henry[/quote'] For the connectors, I went to Pep Boys and looked at their assorted plugs, and found what I needed. I had to buy the pins, and plug seperate for the speedo, and make one. I think for the backup light there was on already assembled that I used. Bring the switch, and VSS with you. I went to a local company that made hydraulic hoses, and had one made. Check your yellow pages. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 12, 2003 Share Posted March 12, 2003 Electrical connectors can be gotten from you local GM dealer. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted March 13, 2003 Share Posted March 13, 2003 For premade AN (JIC) hoses, Check out Grainger, their part #3F807 is a 3 foot long, -4 female/female hose. They have other lengths as well. http://www.grainger.com/Grainger/wwg/homepage.jsp Quote Link to comment Share on other sites More sharing options...
Guest Mr. Big Business Posted March 14, 2003 Share Posted March 14, 2003 Electrical connectors can be gotten from you local GM dealer. I went to the parts counter yesterday and the dude (as usual) was completely clueless. He flipped through several books and could not find part numbers for what I wanted. A couple times while looking at stuff he'd mumble "Park-Neutral switch.." and I'd say, "It's a manual, I just need the reverse switch." I don't think he was grasping the concept of what a neutral safety switch is. Or am I a retard, and the T56 DOES have a neutral indicator type of switch? This seems like it shouldn't be that complicated. Does anybody know of a GM (or aftermarket) part number that will work as a pigtail to plug into the T56? Thanks, Henry Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 14, 2003 Share Posted March 14, 2003 GM does not sell just the plugs. The plugs come with the wiring harness, and you don't need a harness. Go to Pep Boys like I said, I found them there. Quote Link to comment Share on other sites More sharing options...
