Guest Anonymous Posted March 11, 2002 Share Posted March 11, 2002 Water in Oil after day a track. I did not drive the car... so I only know the results. I did a presure check of the cooling system today. After about 7 lbs I could hear the air leaking into the crank case. I had my ear to the oil filler in the valve cover. Could I be luck and only blown an intake gasket. I will do a compression check tomorrow, but doubt that there is a leak in the cylinders since I can hear it leaking into the crank case. I plan to pull the intake look for leaks in the gasket and then replace them. Preasure check again and if it hold preasure drive it. If not I plan to pull the heads. Any other suggestion on how to trouble shoot this issue. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 12, 2002 Share Posted March 12, 2002 What no help? Any suggestions... Quote Link to comment Share on other sites More sharing options...
Guest jwelch Posted March 12, 2002 Share Posted March 12, 2002 Greetings, NAPA sells a block/head crack dye that you put in your cooling system. It has a couple of different mixtures that go in the dye and tell you if the block is cracked or the heads are cracked. I think I paid $50 for it. I thought it was well worth the cost and has descent instructions. Hope this helps some Regards, John 77 280V8Z 66 383 Charger Quote Link to comment Share on other sites More sharing options...
