Ruben Posted March 25, 2003 Share Posted March 25, 2003 Can someone that has a JTR lower radiator bracket be willing to measure their bracket. I need to know the total width of the bracket and the distance between the top of the side flanges and the bottom of the bracket. Would like to see if I can use the JTR bracket with my new aluminum radiator. Thanks, Ruben '72 240Z Quote Link to comment Share on other sites More sharing options...
Guest RisqueRace? Posted March 26, 2003 Share Posted March 26, 2003 Hi Rueben, I just put my JTR radiator support in. I'll give you some measures, but I am not completly clear on what you are asking. Here goes I'll start with the big dimensions and go to small. overall width including mount flanges 28 7/8 width of internal dimension where rad sits 26 3/16 total height including support tube 2 3/8 (od) depth of saddle where rad sits 1 3/4 center measures of header flange saddle braces from one side ( these are offset cause of one tank being bigger than the other for automatic trans cooler applications) 3 1/4 and 2ft 1/2 width of the header flange saddle braces (id) 3 1/4 Hope this helps, It works perfect for my custom Al radiator Bruce Quote Link to comment Share on other sites More sharing options...
Ruben Posted March 26, 2003 Author Share Posted March 26, 2003 Thanks Bruce, that's exactly what I needed. Ruben '72 240Z Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted March 27, 2003 Share Posted March 27, 2003 Ruben, be sure you measure the height of your radiator first. I used the Camaro/V6 Van radiator (the one JTR says to use) and the JTR bracket located my rad 3/8" too high. It hit the hood! Just a heads up. Also, remember to measure with the cap ON. Mine actually cleared the hood without the cap. Quote Link to comment Share on other sites More sharing options...
Ruben Posted March 28, 2003 Author Share Posted March 28, 2003 Thanks Dan, I almost forgot about the radiator cap in my measurements. Ruben '72 240Z Quote Link to comment Share on other sites More sharing options...
