ratedZ Posted March 30, 2003 Share Posted March 30, 2003 Hey guys, well the IC works and I took it for a quick spin. The first run went really well at 10psi...instantly felt the difference. BUT when I came home, my wife wanted to go for a ride and some problems developed. I noticed that it only boosted 3psi and when the BOV opened, it only opened for a split second. I pull over to check and see if I blew a hose or something...but everything looked fine. I revved the motor and normally the blow off valve would discharge but it didn't. I paid closer attention to the rubber hose coming from the intake to the turbo....I noticed that it would flutter and vibrate everytime I let go of the throttle (you can here it flutter at WOT under load). Sooo, I put two and two together and figured that the turbo is not boosting for some reason....any ideas where I need to look? I really need this car on the road for work tomorrow so any help would be GREATLY appreciated. Quote Link to comment Share on other sites More sharing options...
ratedZ Posted March 30, 2003 Author Share Posted March 30, 2003 well...I think I fixed it. My brother was kind enough to point out that one of the friggen vaccum hose directly under the throttle body has blown out. Apparantly I forgot to zip tie it.....DUH! Now the BOV vents when I rev it Quote Link to comment Share on other sites More sharing options...
