280z Gas pig-whats common causes
Well, its officially the season of the $2.50 Gallon of 89 octane here in davis. My 280z has been getting terrible mileage-about 10-12mpg in town... This is terrible. it used to clear 22mpg in town.
So this is whats been checked on it/done:
1. Air filter, fuel filter.
2. new wires. plugs recently done.
3. STP gas treatment
4. Throttle body sensor/wiring replaced.
5. AFM replaced with new unit, boots redone.
Could a mis-adjusted throttle body sensor cause bad gas milage? How can i get the car to run slightly lean? How can i reach the old milage? What can i check?
Thanks for the comments guys...
That big a drop calls for checking the bottom of the tank for a wet spot, watching the fuel pump for leak because of a seperating diaphram, checking all fuel lines both rubber and metal for wetness of gas and the filter too. Also lay out a sleeping bag back by the filler cap to discourage gas predators or, get a new locking gas cap.
