five lug conversion
Guest storm280z
Guest storm280z
can a 1990 corvette 5 lug wheel hub fit on a 77 280z or if not were can i get a conversion kit. or what oem part can i was to do the swap
thanks
thanks
You might get a better response if you post this in the proper forum, like the "Brakes forum" or you may get silence.
That said, the rear hubs are too small to drill out for a Chevy bolt pattern. To go to a Chevy bolt pattern in the front, you'll need custom rotors, etc, which is not cheap, but doable. The better thing to do is to drill for a Ford pattern and then use adapters to mount the Chevy wheels. Go to http://www.modern-motorsports.com/catalog/default.php and look for what you need. Ross C has about everything you could want for such a swap.
Davy
