Guest 240hybrid Posted April 16, 2003 Share Posted April 16, 2003 I have a 87 300zx clutch LSD and inbetween shifts and as I let off the gas I hear a klunk come from the diff. Im running a solid diff mount and installed new bushings throughout the entire rear end, so thats not the problem area. I remember there being a little play when turning the driveshaft companion flange, so Im think the backlash needs adjusting? What do you guys think? Also does anyone know if Nissan makes a shim kit for this specific diff.? Im going up to the dealers tomorrow for contact paste and to find out what shims/adjusting washers I can get through them. Any suggestions are helpful. Thanks Chase Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted April 16, 2003 Share Posted April 16, 2003 i dont know, but i've got the same problem. I got an R200 from a certain very well known zcar parts house that had more endplay than a bad porno... (how's that for an analogy!) with the solid mount, it almost sounds like someone is striking the underside of the car with a hammer when the rear end clunks, and it makes throttle modulation a little tricky... Quote Link to comment Share on other sites More sharing options...
