Guest JAMIE T Posted April 17, 2003 Share Posted April 17, 2003 This past winter my wipers stopped working. I tried another motor(not sure it was any good either), but no dice. I replaced the switch(combo switch) last summer. They worked fine, but alittle slow. Is it likely the motor is bad, or is thier a relay that could be bad? It has been raining it's arse off here in the mid-atlantic states. I've just been applying Rain X every couple of weeks. My other car(the one I pulled the motor off of) has a completely rusted/galled wiper mechanism. One of the pivots doesn't pivot. Anyway, I broke it trying to loosen it up. Anybody have one of those I could get? Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted May 13, 2003 Share Posted May 13, 2003 My wiper go klunk, klunk klunk... while going across. I'm hoping it will work itself smooth over time? The speed is kind of slow too, with a slow normal speed and fast isn't much faster. I suspect the degrade in performance is from the old wiring, just like everything else. There aren't any relays in there because iit's controlled electronically. Maybe somebody has a pinout so you can bypass the controller? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 14, 2003 Share Posted May 14, 2003 Check this post: http://www.hybridz.org/phpBB2/viewtopic.php?t=20857&sid=c74d75efb2625b8ae92e9b9c7bedfd0e Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted May 19, 2003 Share Posted May 19, 2003 Here's a new thing I noticed: Do your wipers OVERLAP? What I mean is that they should overlap in the middle to give a completely wiped strip across the windshield. When I adusted the arms so they park nicely at the bottom of the window, they don't overlap, and it was noticeable driving on a day with light drizzle. I hope I won't need to rely on them to wipe the whole window in real rain. Is it possible I adjusted it wrong, or asssembled it wrong? It seems like there was only one way to assemble, with yth only adjustment being the position of the arms on the pivots. Quote Link to comment Share on other sites More sharing options...
