r230 seal
Guest 3154tm
Guest 3154tm
thinking of buying a 1990 r230 from an infinity q45. it seems to be in good shape but could use new seals. the stub axle seals look straight forward.
how hard to replace is the pinnion/front seal? thanks.
frank
Having replaced a couple of pinion seals on r-200s and r-180, with mixed success I would be hesitant to try it. I have had trouble in the past with getting the pinion torque correct again and have had a diff or 2 that have made noise after relaing that seal. Something about amount of crush on a pinion tube or something. I'm sure someone else knows more. Good luck. Mark
