More T-5 questions
I read the post about using the ford clutch master, but what about running a hydraulic T/O bearing. I would like to run a WC t-5 behind my Lt-1 with a centerforce dual friction, tilton hyd. T/O bearing and ford master. Has anyone done this, (I'm sure), and if so, how. Tanks!!
"Good judgement comes from experience, and experience comes from bad judgment."
Guest greimann
Many are running a hydraulic release bearing, including me, but I remember when I looked into the Tilton unit, they said it would not wotk with a T5. If you get a Mcleod kit from PAW, it will work fine and comes with a matched master cylinder.
Here is a lengthy thread that pretty much specs it out:
http://www.hybridz.org/phpBB2/viewtopic.php?t=18219&postdays=0&postorder=asc&start=0
