Will stock fuel pump run a 350HP V8 in 78Z...
The JTR motor mounts interfere in the set back engine position with the mechanical fuel pump. I do not know about MSA or Scarab mounts and fuel pumps
I realize that this post might have two meanings - stock as in mechanical V8 fuel pump. In this case, it's no, as the JTR motor mounts are in the way, and from what I have read, so are the MSA ones. If you mean will the stock 78 electrical fuel pump feed a 350hp v8, JTR says no, and I still believe it smile.gif
