Guest Venture-Z Posted April 23, 2003 Share Posted April 23, 2003 I have a 78 280 that I'm converting to carbs and putting in an 81 distributer with E12-80 IC modual. Wich wire on the back of the 280 tach is the tach sensor? Do I just run a wire from there to the coil. Can I take the old IC modual out? How about the ECU? Quote Link to comment Share on other sites More sharing options...
Guest PR0ject datsun Posted May 3, 2003 Share Posted May 3, 2003 if you run a wire from the coil, tap into the negative. Quote Link to comment Share on other sites More sharing options...
Guest Venture-Z Posted May 4, 2003 Share Posted May 4, 2003 Thanks!! Quote Link to comment Share on other sites More sharing options...
