I can't remember
Ok this is what I need to ask. I am changing from the stealth intake to a Holley street
dominator single plane intake for (hopefully) more horse power. and at the same time
I am going to delete the valve cover breathers (to messy for me) and go with a PCV
but I can't remember where at the carb it hooks up. (Holley 3310-s 750cfm)
So My Question is What do I hook this dohicky hose thingy to?
Thank You
Jon Peterson
SBC 406 = Datsun 660-Z
Guest greimann
On the passenger side of the carb, on the lower plate, adjacent to the secondaries, there is a 3/8" hose barb. Hook it up there. Be aware, that if it was capped off before, it now will throw your idle off quite a bit.
Also check and make sure its working right after installing it. A REAL high percentage of NEW PCV valves leak and give a vacuum leak of pretty massive proportions. Just something to check, yes mine was defective and I've heard from lots of other people saying the same thing. Good luck with it.
Regards,
Lone
