Moridin Posted May 8, 2003 Share Posted May 8, 2003 When I was looking at doing a turbo swap, or any efi motor for that matter, one of the things that came up was the fuel system. Some installed fuel cells, some used tanks from a efi 280 that fit (can't remember if that's right or not), while other modified their tanks. When I was looking at efi systems for a Chevy V8, I came across this: http://www.speed-technology.com/efi_fuel.html. I'm pretty sure I know how it works, but will it work in this sort of application? Was it made for this sort of thing. If this is a solution, would it be ok to post it in another group? I'm not sure that many of the people as to which this is applicable, actually run through this part of the forum. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 8, 2003 Share Posted May 8, 2003 If you are talking about the surge tank, yes that would work. Some people here are using this type of system. Do a search you will find other ideas. Quote Link to comment Share on other sites More sharing options...
