help....
Guest bigjim240z
Guest bigjim240z
ok..my 81 280zx n/a wont start. i have spark and compression, i have double and tripple checked all connections. i find that there is no fuel going into the engine from the injectors, but i do have fuel pressure at the fuel rail. i was told that the fuel injectors are fired my a signal from the ignition module on the distributor. is this the case?..whatever tells the injectors to spray fuel has got to be the problem. any advice is appreciated!..thanks jim
