Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 I have an Impala with a small block that I am not entirely sure is original to the car. I have the engine number, 10j109299 v0822cnv I need to know if this is a 2 or 4 bolt main, anyone know of an online engine code decipherer? I sure appreciate it! Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted May 12, 2003 Share Posted May 12, 2003 Go here for casting numbers: http://www.mortec.com/castnum.htm Your number doesn't show up though. Look on the left rear of the block near the bellhousing. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 Hmm, I got that number above on the front left of the block, right below the left cylinder head (if you are looking at the front of the car of course). Guess I will need to either pull the engine or snake my way underneath it. I will be sure to bookmark that link though, thanks greimann! Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted May 12, 2003 Share Posted May 12, 2003 It should be visible from the top. It is cast in the block, not stamped. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 I went to http://www.nastyz28.com, and found this number is an engine code stamping number, Engine Code Stamping Numbers All engines are stamped with an engine ID code, consisting of assembly plant code, production date and suffix code. V8 codes are stamped on a pad just forward of the right side (passenger) cylinder head. 6 cylinder engines are stamped on the passenger side of the block behind the distributor. This was the V0822CNV number, which honestly doesnt help me much. Does the casting number indicate the number of main bolts? Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted May 12, 2003 Share Posted May 12, 2003 The info the Mortec provides is thus: CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES So you should be able to tell with the casting number and that site. Quote Link to comment Share on other sites More sharing options...
