660Z Posted May 16, 2003 Share Posted May 16, 2003 Unbolt the rear 2 bolts that hold the lower A arm bushing (leave the front section intact) and take out of holder. Then jack up the strut/drum assmb. until you have the most room outward... it will jack up like this ...)... Then install CV shaft.. This way gives you a good 2" extra to work with, you won`t even have to push in on the shaft, it just goes right in. After your done with the shaft just jack up on the inner controlarm by the bushing and it goes right back into place. Mark Quote Link to comment Share on other sites More sharing options...
