jgkurz Posted May 20, 2003 Share Posted May 20, 2003 Hi all, I did a search on this subject, but found nothing definitive. I'm trying to determine if my stock 77 slave cylinder is the same used on the 83 280ZX Turbo "Borg-Warner" T-5 5spd. Do I need the 83 turbo slave assembly to put the T-5 in my 77? Quote Link to comment Share on other sites More sharing options...
Guest MarksM Posted May 22, 2003 Share Posted May 22, 2003 My trick is to use Oreilly's or similar online parts searches. You can compare part numbers that way to see if they are the same. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted May 22, 2003 Author Share Posted May 22, 2003 I have confirmed that the T-5 did use a different slave cylinder and rod. The hose should be the same as other slave cylinders. Quote Link to comment Share on other sites More sharing options...
