re motor mounts
The back of the chevy hub is not machined flat so I put mine in a disc brake lathe and trued the back up. I used the 3 inch 1/2 by 20 studs and had the chevy hub drilled and tapped for these. If you wanted to spend the money I think Wildwood could supply a hat and rotor to fit over the chevy hub or even supply a hub and rotor. I think the spindle uses a 3/4 inch front bearing and a 1 1/4 rear bearing. I was looking up the bearing on auto zone's web site and noticed it used the same bearing as on my Nova
