Guest tx84ae Posted June 2, 2003 Share Posted June 2, 2003 What's a good intercooler to run in a Z31? I was thinking maybe a stock IC from a MkIII or a Z32... The ver maximum boost I would be running is ~13lbs since I have a T-25... I'm also going for not too expensive here. Thanks for any feedback!! Quote Link to comment Share on other sites More sharing options...
Guest Dan0myte Posted June 2, 2003 Share Posted June 2, 2003 Definitely don't go with a Supra MKIII intercooler. Horribly inefficient. They have a 3psi pressure loss @ 6psi. See if you can find a Starion/Conquest in a local junkyard. Or if that fails, an intercooler from a Dodge Daytona or a Ford Probe will work as well. Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted June 2, 2003 Share Posted June 2, 2003 I like to custom make cores on Z31's but if you need a used or junkyard cooler use a GN unit. You need to mod the in and outlet to come threw the drivers side on any unit you use a Conquest/Starion core can be modded also and fit well, but if you upgrading to anything larger than a T3 you will out flow the core. By the way I would upgrade the turbo first, you are not going to get anything usefull from the T-25. Good luck. Quote Link to comment Share on other sites More sharing options...
