Guest zfan Posted June 4, 2003 Share Posted June 4, 2003 Can I put 17x7 rims on my 1971 240Z? I have arizona Z springs on all four corners so it sits up pretty high. I currently have 15x7.5 fluted Centerlines with 25.5" tall tires on it with plenty of clearance. If I remember right there was a discussion re: 17's not fitting or needing coil overs on all corners? I do know if they fit I will need Ross's adapters as they are 40mm offset. Damn front wheel drive crap. Mike Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted June 5, 2003 Share Posted June 5, 2003 17x7s will fit fine assuming you have the correct offset or at least the correct adapters. Quote Link to comment Share on other sites More sharing options...
