Guest Anonymous Posted June 5, 2003 Share Posted June 5, 2003 Hi guys Thanks For this Awesome Sight...... Ok my parts Car Has New Struts All around And it is lowered About 2 inches. I changed the front units . that was the easy Part. The back is a pain in my a--. i would like to just change the strut unit and spring. is that a cartridge)if so how do you get it out the hub. Or is it one Unit (strut and hub made toghther. if its a cartridge how do you get them out presses in or scewed..... One more Question... What the east way to get that pin out from the tranverse link..Towards the outside of car. The book says it comes right out once You take that pin out of the middle of the Shaft... But mine Not Coming out to easy.... Thanks For any infor... i hope to soon put some pic on..... Thanks Again. jim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 5, 2003 Share Posted June 5, 2003 Front strut cartridge comes out same as the rear, held in by the gland nut. Don't try to pull that pin, it wont come out without alot of effort, persuasion, heat, cussing and blood. Just un bolt the rear control arm, four bolts on each arm, two toward the front of the car and two toward the rear. Then just drop the whole rear control arm and the strut housing. Mark Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted June 5, 2003 Share Posted June 5, 2003 Jim, I am going to assume that you are putting the new struts from your parts car in to another Z correct? If so, then you already know how to change the rear struts, they are the same as the front and yes they are of the cartridge type. Here's what you do if you want to leave most of it attatched to the car: - Take off the three nuts inside of the car that hold the assembly to the strut tower - Disconnect the sway bar if you have one - Disconnect the half shaft - Remove the brake line (may not have to do this, BUT make sure it is not kinking the brake line in any way if you don't) - Pull assembly out so the top is outside of wheelwell - Get a spring compressor and compress the spring - Remove the isolator nut on top of the strut assembly and pull off the spring - Get a pipe wrench or something that will take off the gland nut (the nut at the base of the shinny rod from the strut cartridge) - Pull out the cartridge Believe me when I say that for some people it is not that easy, just click on my WWW link in my post here. Sometimes over the years metal things get fused together by water and rust. That strut pin is a pain in the @ss! It should come out with a little cussing, some heat, and penetrating liquid. Worse case is that you have to cut the pin out with a sawsall, have the pieces pressed out and you have to buy an expensive (~$25-30) pin. You should really get yourself a service manual, it makes things a little bit easier. !M! Quote Link to comment Share on other sites More sharing options...
