200r4 mounting
Hey yet another question. You guys are so good at answering all of them just had to ask another. I need to know if the 200r4 and the 700r4 have the same mounting pattern. Basically can I use a crossmember designed to mount a 200r4 for a 700r4. Thanks
Jared it is my understanding that there is a universal transmission mount that fits a lot of GM products but the crossmember maybe located in various places. The universal mount that I have has three holes that can be used for the crossmember and two holes on the other side for the trans . you can use 3 holes 2 holes and or 1 hole to the cross member . I plan to use one center bolt hole to connect the mount to the cross member and of course the two bolts to the tranny a very simple rectangular rubber encased trans mount about 2x5 inches and 2 inches high
