240hoke Posted June 17, 2003 Share Posted June 17, 2003 I've got two differnt part numbers on my injectors: E5ZE-A3B and A5ZE-A3A. For those that are using these or have used them, Is there a differnce between the two and what are the part numbers on you guys' injectors. Thanks -Austin Quote Link to comment Share on other sites More sharing options...
spork Posted June 21, 2003 Share Posted June 21, 2003 if you have an autozone nearby you, go there, and look up injectors for the svo. Listed in there system they will have lots of different oem part numbers the injectors. You want the later yeared svo injectors as they were the higher output ones. I'm not positive, but I've been told that the earlier ones weren't brown tops. So you should be safe if you have the brown ones, but go to autozone and check for yourself Quote Link to comment Share on other sites More sharing options...
aarang Posted June 22, 2003 Share Posted June 22, 2003 I have 2 of the "B's" and 4 of the "A's". They all flow the same. Hope this helps Quote Link to comment Share on other sites More sharing options...
240hoke Posted June 22, 2003 Author Share Posted June 22, 2003 Thanks for the info guys -Austin Quote Link to comment Share on other sites More sharing options...
